- Thread starter
- #121
So how big are these samples?
landtank said:So how big are these samples?
landtank said:enough for 2 clutches then.
Tools R Us said:1.7 oz for a fill, so 4 fills?
landtank said:...
Just took the clutch apart. Looks like there was plenty of oil in it. Oil was golden in color and seemed in good shape. No where near as thick as the 10k stuff I got.
landtank said:Tools, any way to remove that ringed disk from the drive side of the clutch? Or do you figure on letting it drain over night and flushing with acetone in the morning.
cary said:Just my thought, but a plugged radiator could interfear with the operation of the fan clutch. If the clutch depends on heat from the radiator to activate the clutch a plugged radiator will not allow proper activiation. This would occur because the plugged radiator would not allow hot coolant through, causing less heat to be transfered from the radiator into the airstream reaching the clutch and thereby causing the clutch not to activate when it should. It seems this could create a vicious cycle, as then the clutch will not cause air to be pushed through the radiator leading to the engine running even hotter.
landtank said:...
I'm thinking that if that spring is at 140* the water in the radiator has to be even hotter. Anyone have an idea how much hotter?
I'm going to set the plate for an earlier engagement and see what happens.
landtank said:Radiator is less than a year old and an aftermarket clutch solved the over heating issues.
For better or for worse I'm completely convinced this clutch has an inherent problem.
Gauge said:Seems like the Hayden clutch fan cycles on and off - pulling a lot of air and then after awhile winding down - only to turn back on again. Is that normal?
Yes, that sounds good. It should cycle like that so it can hardly engage at fast highway speed yet engage fully when the motor is at high revs travelling slow in the indirect gears or low range.Gauge said:I second that. Pulled the OEM clutch fan off tonight and guess what - not working. I opened it up and it had VERY little oil inside.
I installed the Hayden I picked up from Pep Boys and it seems to be working - it makes the loud roar at startup - which I didn't have before.
I drove it around with the AC on trying to make the engine hot, but the temp gauge stayed low.
