Replaced these on the 80 before but not on 100. Any tips&tricks to making it a quicker and easier job?
midwest2 said:I did mine last year and it was pretty straight forward. I did the thermostat at the same time so the lower hose was out of the way. I pulled the fan and fan clutch out as one unit then changed the clutch on my bench. I was able to get it out without removing the radiator shroud.
Any advice on how to keep the whole assembly from spinning around while trying to unbolt the fan clutch from the engine (the four 12mm bolts that hold the fan clutch to one of the pulleys on the engine.)?
When I try to turn the bolts, the whole assembly just spins (slips on the belt)... driving me nuts!
Maybe a Klein strsp wrench like Spress posted above.
Put a second wrench on one of the other nuts to hold it in place.
