Thanks 92B.
This is mostly for Cruiserdrew as he requested pics of the 14bolt that came out of the stepvan. I yanked it and put it on some jacks and it's been there ever since. It's got dually hubs which gives me 63" wms and all the stepvan stuff I've read leads me to believe it's a 4:10 ratio inside but I haven't pulled the cover to look yet. It still has the monster heavy drum rotors.
This is what is stamped on the housing.
For cruiser time I've noticed that my block heater wasn't working. With it being cold Dora is unhappy and starting isn't as smooth as it used to be. I think cylinder 3 is getting worse. I checked connections to the heater and found nothing and then I checked connections to the plug and found one of the wires out of the terminal so I cleaned it up, put it back in and screwed it down. This morning's starting was the normal 1 chug and start.
I checked the power connections to the tranny control box with a voltmeter and found nothing loose or out of place but the indicator won't light up correctly when selecting the knob through the gears so I'll continue to investigate. The tranny is running warmer than the old tranny which isn't a big deal in the cold but I'll want to look into it when it warms up, maybe I've simply got the cooler lines hooked up backwards. So far the new system is working out pretty well and I am liking it.
I found the swagelok valve that I'm using for a line lock to be leaking. So I took off the lever (just an allen head set screw) to look underneath. There was a swagelok guy here at work in the summer time and I told him I was using one of their valves. I told him it would slowly leak down pressure and he said to take off the lever and tighten up the disc to seat the ball valve a little better. He said they wear over time that to keep their performance just tighten them up. You can see the disc with two holes in it. I'm positive there is a much better tool and a specific tool but I just used some c-clip pliers and tighten it down. Before the lever had very little resistance and now it's tighter. It's now a little tighter than when I first installed this and the leak stopped.
The city got some snow yesterday and I took Dora out for a spin. Traffic was crazy and there was one particular hill that was giving a few cars some problems. I ended up pulling someone out of the way and up the hill to get her on her way. I went back to pull some others that were stuck but they cleared out before I got back so I just went home.
My next project to focus on will be the steering system. New Tie rod, ends (still need to order these and might have to wait a paycheck or two), reseal the steering box, reseal and valve mod to the steering pump.
Also hoping to get some time over at Brokenparts' place this next month to get his rig ready for Moab.
