- Thread starter
- #1,121
weekly update
I went to the store to find new gasket material for the antenna base because the one I made was just too thick. I found a tire repair kit with a circular patch that looked promising and then found an outside wall outlet cover with a gasket and opted for that (it was cheaper). Turns out the gasket has stamped precuts that you remove to get which hole size you need so I wasn't able to use this as it interfered with cutting a circle out of it. Back to the drawing board. As I was telling the
that my rubber gasket for the antenna base was too thick she went downstairs and pulled out some "fun foam" she got from somewhere. It was just what I was looking for so I traced it and cut out a new gasket piece.
As I was doing that UPS showed up and delivered my antenna and coax cable. I got a top-loaded 3' K40 SuperFlex in white with the tunable tip and a 9' coax with one end a P259 connector and the other end spades. I found them for a good price off of amazon.com.
I pulled the coax through the passenger side wiring gasket.
I decided to tag off of my radio to get the constant 12v and the switched 12v and then grounded the CB to a dash brace.
I put the antenna together and wired it up. Using a SWR meter from a friend I started out with 2.8 - 1 which is close to 3 -1 meaning don't operate your radio because it can ruin it. Using the tunable tip I got channel 1 and 40 down to 1.5 - 1. I originally had the coax cable grounded to a bolt holding the ball mount to the fender but that wasn't good enough so I ended up grounding to the battery and performance improved. I found a channel with clear activity and got a location from a local truckstop that is 9 miles away from my house. Pretty good considering I live in a city with hills and buildings and I was able to reach that far. I'll have to see what it does on the open road.
I did some reshaping of the skid plate and cleared a rub point. Unfortunately I missed two more and will need to pull it off and clearance those parts before the event this weekend.
I got the front tires siped hitting the alternating small blocks of the center lugs. That leaves the larger lugs for now in case I want to groove them; if not I'll just sipe those too. Not sure I'll get the rears done before the event but I'll get them soon.
I also replaced all my heater hose with gates green stripe. I found another one leaking so I just got 10' of hose and hit them all.
