you make it look way too easy in your videos.
I thought those silicone elbows are rated to 60 psi. How much boost are you making out of those twins? Great job on creativity. I'll add duct tape to my inventory.
I was experiencing this odd midrange loss. It felt labored and somewhat struggling. I could push past it and the power was back but it almost felt like a miss in that part of the power range. This symptom stuck around for a while as I continued to throw money at it and try out different tunings.
I started playing with injectors.
I picked up new tips and eventually had the pop pressures set to 252 BAR. The new tips are 5x.012 SAC. Now in hindsight I would have set these to 260 bar.
Here's a comparison of the different tips. On the Left are the 5x.014 SAC that I ran for a short while. These were just too big for my set up and what I like. The Middle is the 5x.012 VCO marine nozzle that came on my engine that I've run for several years. On the Right are the new tips, 5x.012 SAC. You'll notice that even though the left and right are both SAC tips they are different sizes. I choose SAC tips because they have a history of being a little tougher than the VCO tips but who knows.
They'll never be this clean again. I used the thinnest sealing washer (~.020" thick) when I put these in.
Then I had to do a bunch of tuning again to play around with them. Ultimately I still had a lazy midrange.
Next I tried an even freer flowing air filter. This is R2C performance newest offering for turbo street application. Because it flowed more it didn't need to be as big. I figured I'd use the Black Hex on the street and then swap over to the White media when I went offroad.
While there was a slight improvement in spool up my midrange symptoms still existed.
Hah, good job on the zip ties. Have you figured out if it's just the pressure taking the hoses out?
Or engine vibrations/tilting?
How did you set your pop PSI?
How did you determine which size sealing washers you needed?
Where did you get the tips from?
I think you need to drive my stock 105 HP with an h1c and you''ll remember how far you've come.
