- Thread starter
- #21
Thanks for the advice. The previous owners were kind enough to have toyota install new: EGR vacum , TB Gasket, Idle control valve, EGR valve, EGR vacum, EGR gasket, PCV valve and an Idle Valve gasket in the rebuild 60k back.If you're doing the spark plug tube seals (which requires removing the valve cover) you'll also want to replace the valve cover gasket, the PCV valve grommet, and the Throttle Body gasket.
And to remove the Throttle Body you have to disconnect a small diameter water bypass hose from the underside of the TB, so it's easier to go ahead and replace that hose if it's age is unknown while you're in there.
And while the TB is off it's easier to clean out the 25 years of sludge/carbon
that builds up in the TB and on the butterfly valve. You can also reach in and to some degree clean up some of the intake plenum.
And if your EGR system is still intact you could clean out the EGR port/passageway where the gases flow from the EGR valve to just behind
the Throttle Body.
And while you're doing that you can remove the EGR valve and clean the carbon out of that, check it's function, replace if necessary.
And with all that out of the way you can inspect and rewrap your engine harness where it comes close to the hot EGR pipe and then add a heat reflective/insulation sleeve.
And to get the valve cover off you might as well remove and replace the heat control valve on the firewall while you're in there (if it hasn't been replaced) and then the hoses connected to that, if not the rest of the heater hoses in that area.
And don't forget to clean out the oil baffle located on the inside top of the valve cover; that can become clogged with sludge which is difficult to clean out, one can of Brake/Carb cleaner won't be enough. That's where some Simple Green or Purple Power can help.
And heck, if it hasn't been done yet, might as well replace the distributor O-ring.
So one job can turn into 12, 14, 20---, while you're in there.
I looked at the invoice but I cant tell if the gasket kit, 04112-66035, used for the rebuild comes with the spark plug tube gasket. I looks like the kit contains the valve cover gasket. Maybe the cover hasn't been retightened since the rebuild/ (Wondering if the valves may need to be looked at).
