Valve cover gasket job gone bad - dropped nut into timing chain cavity
That’s awesome!! Glad you found and good work getting the pans off.
Pro tip for the valve cover bolts, you can always go back and drill it out and fix with helicoil. If you look closely at my second pic you can see I helicoiled all the #2 pan threads in the #1 oil pan. Aluminum is easy to drill and tap and helicoil will make everything stronger.
