bobm
WTF, WTF, WTF!!!!
Where are you measuring from? Beginning of tape??
Beginning of tape to the inner most, big pully groove (3 groove pully)Where are you measuring from? Beginning of tape??
Wondering if there’s any kind of a differenceI have the F and those brackets. These are the ones from the 2 f
Thx pighead.That gives me a little confidence. As some of you might recall, I'm pretty green! First engine swap. I just don't know what to expect or when to throw up the bat signal.Engines sit slightly crooked in the engine bay, they just do...
Could very well be, i forget. 2F seems to have bigger bolts everwhereBeen thinking these new rear motor mounts have larger bolts that the originals,
I probably wasn't very clear when I described how I measured it. I did use the face of the pully so the end of the tape was on a solid surface. I brought out my straight edge to make sure the surface I was measuring to was flat, which it was. Hard to tell in the picture because it juts upwards a little but on the plane I was measuring to it was flat. No doubt things are off center a bit. I guess my question is how far out of "true" is OK. The farther it gets, the more the drive shaft will be on an angle. It's obviously designed to handle angle changes, but I have to assume the more true the better.I'd measure off the face of the pulley. Use a framing square across the face and measure it like that. See if it makes a difference.
Can you not put in a few washers between the back motor mount and the bellhousing to move the back of passenger side of the engine over a little? The bolts that thread into the bellhousing are long and will easily accomodate a few washers. I'd have all the motor mounts bolts loose, align the engine with any necessary washers and then start tightening it down and checking to maintain alignment.Thinking about pulling the rears out, making the hole a tad bigger. With the extra clearance around the stud, I bet I could get it a lot closer anyway.
