This last weekend of wheeling in Clayton, OK has told me I need power steering, among other things like more lift, bigger/wider tires and that 4spd swap I have sitting in my garage. I must "go big or go home!".
Okay, I have a '72 "F" engine with stock Aisin carb on stock manifold. I have swapped out my old tin valve cover for a better sealing aluminum '75 "2F" model.
I want to put on the mini truck power steering setup and understand that I can't do it with my stock "F" air cleaner setup -- the power steering pump fits in that place
Here's my problem/possible solution: I figure I could just put a '75-'87 "2F" air cleaner setup on there and be done with it. But, I don't have a stud in my "F" carb for the air cleaner Is the "2F" air cleaner inlet the same size as my "F" carb throat? Could I plug the stud hole on the housing use a hose clamp around the throat like the "F" setup?
Have any of you done anything like this? Any suggestions? :-\
Another reason I want to use the "2F" air cleaner setup is that it will work with my homemade snorkel setup I have attached to my "F" air cleaner now
Jody.
Jody.
