Extended bumpstop pictures needed
Atascadero, CA
i did a little searching but couldn't find exactly what I was looking for. I just installed an ome 2.5" spring kit on my 40 and I'm looking at reworking my bumpstops all the way around. Does anyone have pictures I could use for ideas? I'm trying to keep these tires from getting destroyed by the body. Air bumps would be best but out of my price range right now.
Thanks
Here's more on Mark's Off Road bump stop extenders
ABS for your FJ40- Asymmetrical Bump Stop Extenders
Few Landcruisers I see in my shop or on the Net are still in completely stock trim. Even amongst the resto crowd, modest lifts are common. And the wheeling crowd usually sports several inches of lift on their rigs.
Of course, right after the lift comes the larger tires that the lift helped accommodate in the first place. But what about sheetmetal clearance? Once the larger tires are installed, the likelihood is that they will contact sheetmetal long before the axle hits the factory bump stops.
In my opinion, extended bump stops are one of the most under-considered aspects of a lifted Landcruiser. In many instances, Landcruiser owners do not even consider extending their bump stops until they experience either a shock failure [from collapsed stress] or sheetmetal damage. Further, in the vast majority of cases, the extensions that are offered on the market are sub-optimal in that they are designed to mimic the truck‘s original suspension geometry, which does not line up properly with the lifted vehicle. If you think about it logically, you can see why it would not.
When add lift to a leaf sprung vehicle, the frame end of the spring remains anchored in the original location. Therefore, a spring lift can be described as increasing a pie wedged shape between the axle’s old and new locations relative to the frame directly above it, with the frame end of the spring at the apex of the wedge.
Further, when the axle moves upwards towards the frame, it does not move directly up and down, but in an arc, again with the frame end of the leaf spring as the anchor point. Therefore, the point at which you will want the axle to contact the bump stop is not likely to be directly below its original location, but somewhere out on an arc that is closer to the frame end of the leaf spring. Enter the ABS.
I designed the asymmetrical bump stop extenders to help move the factory stops into an orientation more likely to make an ‘even’ contact with the axle than ones lowered directly down from the stock location, which becomes more critical as lift and tire size increase. I am currently offering the ABS in three nominal sizes, with increasing tapers appropriate to their lengths: 1.5”, 2.5” and 3.5”.
Thank you, that's along the lines of what I'm thinking as far as adjusting the angle as well as extending the bump. My factory stops are either trashed or missing completely so I'm thinking about going the universal route. I already have shock hoops up front and shocks through the floor in the rear, adjusting those accordingly is a whole separate project.
I have a rough idea of what I want to do but seeing other people's setup is always helpful. My 40 has seen much better days and I'm not the least bit afraid of heavy modifications, I can't mess up something that's already destroyed haha. I just want to do it one time and be done without trial and error.
I'm toying with the idea of mounting the pad itself on top of my ubolt flip plate and putting a contact plate on the frame.
http://www.marksoffroad.net/1specials/1specials.html. Scroll down this page he has extended mounts... He doesn't do email/PM so you have to call him.
By the way, show pics of the OME lift on your rig, shackle angles etc. please.
I will get some pictures up as soon as I can. Still getting the last spring on, thought I'd be done today but 90 degrees and humid in my garage makes everything take a lot longer. Hopefully I'll have it 100% this week. I wanted to address the bumps before I get the wheels back on but I think that may be putting the cart in front of the horse.
Here's mine...
Bump on an old thread, looking for a set of Mark’s 1.5” extended Bumpstops.
Has anyone acquired a set recently, know if they are still in production, or have a set for sale?
