FJ60 10/84 build date, Exh/Int manifold off the truck. I'm in the process of replacing stock isolator with a SOR SS isolator.
While doing that I've discovered that exhaust ports 4-5 are not flat - Shocked aren't you! I was to.
So, I'm in a pickle... no local machine shop (Western CO) will touch this FJ60 Exh/Int set-up (all the threads say machine as a complete assy only). I also don't want someone to 'practice' on my only set. The cost of shipping from here to Timbucktoo & back is also an issue... If I could even find a shop that has experience.
How about two gaskets! I have a stock already, what else to go with it, Felpro? I also thought about using Permatex Ultra Copper RTV on the stock gasket, but having mixed feelings now.
Here is where you all come in...
1. What approach is 2nd best - assuming I can't get the assy machined?
2. Anyone used Ultra Copper with success?
3. What is the torque sequence & values when I put the Exh/Int manifold back on?
Thanks in advance
PS: I looked into a new assy, $1000 from SOR - not in the budget.
Thanks in advance
