I passed emissions here in Denver once I discovered and removed a BB in the EGR hose. The truck would sputter while driving, so I put a BB back in the hose when I returned home, and the truck ran fine.
However a month or so after that the truck began stalling off and on, but it wasn’t very often, and would start right back up. Now it stalls more regularly so I have been trying to trouble shoot my issue.
Back in August I was in Ouray at the Solid Axel Summit, and @abtx4x4 showed me what hoses to switch on my charcoal canister thinking that check valve was causing fuel starvation, which I did and it ran great for two weeks.
Then @2mointainfish reached out and helped walk me through removing the ICS or FCS solenoid from the carb, inspect the o-ring, spray carb cleaner into the port, and reinstall, which I also did. The problem however is still there.
Here is an outline of what I am experiencing:
- Truck starts fine, and idles with no problems at around 500 to 600 rpm
- Drives great in downtown like conditions for 20 to 30 mins
- As I am coming to a stop in neutral it stalls
- In order to restart I must pull the choke out all the way and press on the gas pedal
- It drives with a slight sputter in 2nd gear, and will stall again when I go to stop in neutral
- In order to prevent stalling I must keep the choke out so the engine does not drop below 1000 rpm
- Drives with no problems with choke out for another 20 to 30 mins
- I then push the choke back in all the way, and I drives fine with no stalling issue
