Engine Overheating - 2004 LC (5 Viewers)
Denver
Hello all,
New to this forum, but have been lurking for quite some time.
Bought a 2004 with 210k miles, great service records up here in CO. I changed the heater tee's out last week and bought a scan guage, beacuse well, it is an old car and I wanted to drive it with a better understanding of temps, etc., and just make sure no weird underlying issues presented.
Current issue at hand:
The car overheats in the hot summer. Mainly stop-and-go on the freeway (96 ° yesterday) for an hour or two, AC on. Temp creeped up to 236, so naturally I shut the AC, turned on the heat, and let it cool. Car has been fine when moving quick down the freeway, was sitting at 186-190ish the whole way to work today. Around town on a hot day, a little higher, but not near the 236 range unless AC is on. I have been gentle and keeping the heat on and windows down in my new mobile sauna.
Findings & insights:
-Removed most residue well from older heater tees that crumbled a bit when swapping
-Coolant levels are good. Rad and Overflow (Maybe it needs to be bled?)
-OEM Thermostat was put in 10k ago, as well as a coolant flush
-99% sure radiator is original
-Points me to the fan clutch, fan clutch doesn't move freely when the car is cold
-Could it be as simple as a radiator cap... No, it couldn't be? Right!
Any advice would be great at this point! If I can't figure it out off it goes to a local Denver Mech.
Cheers.
Sounds like you've checked the obvious stuff. Could be a radiator cap like you mentioned but probably not. More likely when we see temps rising in stop-n-go its related to fan/fan clutch or debris in radiator.
Remove skid plate and check radiator all over, spray it down and clean it up.
I forgot how to diagnose the fan clutch. When cold, you should hear it roar when the engine starts and slowly quiets down. When you shut down and its hot it should be hard / feel resistance when spinning the fan. (belt removed for testing)
Start easy and check radiator and replace cap with OEM but start doing research on replace fan clutch
If you changed the heater T's it's possible you've got air in the system.
Might as well throw a cap on, below are some photos of the rad/condenser. They don't seem too bad. Will look into the fan clutch next, thanks for the reference.
