Engine oil and jacket temp gauge replacement (2 Viewers)
QLD,Australia
Hey,
I have 1981 2H engine
I just purchased PWT gauge from red arc. Found a shop that makes reducers but unsure of cylinder head thread is.
Cylinder head size looks maybe around a m18x1.5
the oil sender I think just needs a 1/8” bspt to 1/8” Npt adapter.
this is the OEM oil pressure sender
redarc sender threads are 1/8” npt
a replacement water jacket sender
NPT = 27 threads/inch. BSPT = 28. You need extraordinary vision to discern the difference!
Are you certain that the new sender has tapered threads?
well redarc data sheet saying 1/8” NPT,
It doesn’t look tapered though which is confusing me,
im really chasing the block thread and size
below is the jacket water temp port I want to.
@47HUNDR
It's likely the threads on the water jacket are BSPT as well.
BSPP / BSPT​
BRITISH STANDARD PIPE PARALLEL / BRITISH STANDARD PIPE TAPER
55 Degree Threads
SIZE
TPI
MAJOR (EXT)
MINOR (INT)
TAP DRILL
1/8"
28​
9.728​
8.566​
8.70​
1/4"
19​
13.157​
11.445​
11.60​
3/8"
19​
16.662​
14.950​
15.00​
1/2"
14​
20.955​
18.631​
19.00​
5/8"
14​
22.911​
20.587​
20.75​
@47HUNDR
BSPP / BSPT​
55 Degree Threads
SIZE
TPI
MAJOR (EXT)
MINOR (INT)
TAP DRILL
1/8"
28​
9.728​
8.566​
8.70​
1/4"
19​
13.157​
11.445​
11.60​
3/8"
19​
16.662​
14.950​
15.00​
1/2"
14​
20.955​
18.631​
19.00​
5/8"
14​
22.911​
20.587​
20.75​
Are those metric measurements on the major and minor column?
Ordered some fittings through speed flow,
Oil pressure sender 1/8” bspt male to 1/8” npt female adapter
water jacket
There’s a spare plug that the previous owner had a mechanical temp gauge wired in and from what I’ve found going off part number looks like a M18x1.5
so I’ve gone a M18x1.5 to 1/8”npt reducer.
