Engine Coolant Temp. Sensor (1 Viewer)
I installed an UltraGauge.
It has to have OBDII to work though, so limited to some 95, and 96 and 97 trucks.
I have an alarm set so it beeps at temperatures over 200 degrees F.
And, it tells you what the computer is seeing so you know the health of your sending unit.
I consider it a well spent $70.
t
unfortatunatley i have the obd1..otherwise it would be first on my list, i have a (1993 1FZ-FE)
have a look at these new quality gauges from redarc
http://www.redarc.com.au/products/category/monitoring-gauges/
There are two different engine temp sensors: 1 for the gauge (temp sender) and 1 for the ECU for the EFI system.
Two completely different functions and roles within the 1FZ-FE operational system.
This discussion is going in two different and divergent tangents.
If you are throwing a temp sensor code than you need to test the sensor for the ECU not the one for the sender to the gauge.
Hi Beno, Thanks for chiming in. I think I need to test and/or swap out the sensor for the ECU. Where is that located (photo?), and do you sell them? Thanks,
Muddy1
I changed the ETCS last week on my 97 LX. The sensor is a bitch to reach, heck I had a very hard time seeing it. I ended up taking off the drivers side wheel and one of the plastic flaps in the wheel well to reach the sensor. I used a 19 mm deep well socket on a universal with a 2' long extension and ratchet through the wheel well. For some reason I was not able to fit the deep well socket on the sensor. The plastic electrical connector part of the sensor was too large for my 19 mm socket so I ended up breaking off the plastic part so I could get the socket on. After that it came right out.
The new sensor did not come with a gasket so I reused the old copper washer from the old sensor. I installed the new sensor, refilled the radiator and reset the check engine light. So far it has stayed off.
Well it's been 3 years since I changed out the ETCS and I got another P0116 code check engine light. I used a scanner to check the live coolant temp and it read low, about 90 degrees after driving the truck for a half-hour and getting good heat out of the heat ducts. The gauge also read OK with the needle in the middle so I did not suspect a stuck open thermostat. I changed out the aftermarket sensor with a OEM sensor and cleared to code. Refilled the radiator (about a quart lost when swapping out the sensors) and fired it up. In a few minutes the scanner was reading coolant temps around 180+.
FYI, the new OEM sensor came without the little copper washer seal so I reused the old one. Careful not to drop it when installing! I'll add a pic of the wire connector and the sensor location. This time I used a 3/4" deep well socket with about a 8" extension working from the top driver side of the motor, not the wheel well. Seemed easier this way than through the wheel well.
FYI, the new OEM sensor came without the little copper washer seal so I reused the old one. Careful not to drop it when installing! I'll add a pic of the wire connector and the sensor location. This time I used a 3/4" deep well socket with about a 8" extension working from the top driver side of the motor, not the wheel well. Seemed easier this way than through the wheel well. View attachment 1580055 View attachment 1580054
Bump
Good morning
I'm in the process of performing some preventive maintenance and I'm unclear on which temperature gauge is for the ECU and which temperature gauge is for the dash gauge.
Based on my reading the dash gauge is the one on the driver side above the oil filter is this correct?
If so where is the ECU temperature gauge located?
I looked in the FSM but didn't see anything.
Bump
Good morning
Put your year model Cruiser in your signature line so we will know at a glance what we are dealing with.
For those with 1FZ-FE engine (U.S. Market).
All of the coolant temp sensors will leak out some coolant when removed as they are located in the head (where coolant flows) with the tips surrounded by coolant ie: so they can measure the coolant temperature.
What are you working on, are you wanting to replace a sensor, why, engine codes or??
1FZ-FE. I do have the code for this and also a knock sensor. Also cold start is tough and sometimes stalls. And the plug is sheered off.
Are you installing an OEM ECT sensor (89422-35010)? If you need to save a few dollars RockAuto sells an AISIN Sensor (THSAZ-8001) for $18.
Fix the ECT first, clear your codes, then see if the knock sensor code comes back.
Check to be sure there are no air/vacuum leaks (air intake hose between the pleats, PCV or breather hoses)
If you do have to replace the knock sensor it will not leak coolant (or oil). Amayama currently has a good price on the Toyota part (89615-30050)
Thanks all good info. I don’t have a way to clear the code as I had it diagnosed but decided to do the work myself. Is there a way to clear it? Disconnect battery? I did have a bad EGR which I replaced then also did the heater control valve and some hoses. All OEM. One thing, on my EGR, I did use slightly larger diameter hoses and clamped them. They’re a little loose but stay put. Could this be an issue? Could I do my knock sensor and coolant sensor at once while I’m in there then reset? They’re Amazon but I got the most expensive Amazon ones 🤣 as their stuff can be crap and these got 5 stars.
Switched out the sensor. Listened by wrench and didn’t remove the wheel or anything. Did the swap by hand the tightened and reconnected the plug easy peasy. Luckily the sheered piece came out pretty easy. Started up and runs great. No CEL and all sensors and connections are good to go. Thanks a bunch. Didn’t spill more than half a cup o coolant tho.
