O2 sensor installation
are you re-using the existing gasket or installing a new one? If new one, no form-a gasket needed.
I'd suggest putting a little dab of copper antiseize on the O2 sensor threads if the new sensors didn't already come with it applied. Using antiseize on the threads will make removal of the sensors later on alot easier. But just a word of caution, make sure the antiseize doesn't get on the tip of the sensor that's sticks into the exhaust stream.
Related: The reason I'm replacing the gasket is because the nuts backed all the way off on their own somehow, to where they weren't even on the studs anymore. The sensor was still on the studs but just flopping around, and the exhaust leak ate up the whole gasket. Anyone else ever have that happen?
This is the correct use for anti–seize. It was designed for bolted connections on boilers. Repeated heat and cool cycles suck water into the threads and seize them together. Anti–seize is heat–proof wateproofing.
