Help!
I replaced my power steering pump (new OEM), high pressure line (new OEM), and retrun lines, put it up on jackstands and started to bleed out the system but it seems like the fluid wont clear up!
I've left off the return line that goes to the res., plugged up the bottom of the the res. and routed the return line to a clear plactic bottle. Before the res. goes dry I fill it back up again (5-10 seconds of cranking the wheel from stop to stop with the engine running at 800 RPM). After 2 quarts of ATF there is still ALOT of bubbles comming from the return line!
What am I doing wrong?
Toad
Toad
