Endless Bubbles during power steering bleed
Discussion in '60-Series Wagons' started by Toadhopper, Aug 13, 2005.
  1. Toadhopper
    Toadhopper
    686
    4
    May 19, 2005
    Help!
    I replaced my power steering pump (new OEM), high pressure line (new OEM), and retrun lines, put it up on jackstands and started to bleed out the system but it seems like the fluid wont clear up!
    I've left off the return line that goes to the res., plugged up the bottom of the the res. and routed the return line to a clear plactic bottle. Before the res. goes dry I fill it back up again (5-10 seconds of cranking the wheel from stop to stop with the engine running at 800 RPM). After 2 quarts of ATF there is still ALOT of bubbles comming from the return line!
    What am I doing wrong?
    Toad
  2. Toadhopper
    Toadhopper
    686
    4
    May 19, 2005
    Nevrmind I got it.
    I was just letting too much fluid out and reintroducing air into the system each time.
  3. treerootCO
    treerootCO Where are my keys?! SILVER Star
    3,781
    Media:
    45
    Albums:
    1
    825
    Jun 2, 2004
    Wheat Ridge CO
    Over fill it and put the cap on real tight with the engine running. As soon as you turn the key off, the fluid will rocket out the little vent hole. :D
    I bet I cleared 30 feet last time. Might not work on a 60 though, have to have a vent hole...
  4. crawlin60
    crawlin60
    135
    Feb 27, 2002
    Toad, tell us what a pump sells for these days, wouldya?
  5. hammer1
    hammer1
    791
    2
    Feb 11, 2005
    morristown nj
    i got a re-built oem pump from the local napa guy for 199.00 leass the core. but that was aftert two aftermarker duds. i KNOW it would have been more, but for all my miserey, he just exchanged it.
    good guys at the Advantage Auto Parts,
    Speedwell Ave.
    Morris Plains nj
  6. Toadhopper
    Toadhopper
    686
    4
    May 19, 2005
    Got it from CDan for $309 INCL SHIPPING!!
    The HP hose was another 100 (ouch). The pump is quiet and best of all its really shiny!
