Update, win some and lose some
So its been a few weeks since we dealt Elsie any TLC, but Memorial Day seemed like the time to give her a new go, and what an afternoon of ups and downs:
- Pulled the air cleaner top and made sure the carb didn't have the choke plate closed (choke engaged) since the old cable is really rough and needs either an overhaul or replacing
- Pulled the dizzy cap to expose the rotor and grabbed the old crank from under the seat, turned her to the timing mark on the flywheel (rusted over)
- Roughed off the grime and rust on the flywheel BB with a cleaning pad, hit it with a Sharpie Paint Pen in white
- With the engine sitting at 7* BTDC, I turned the dizzy to approximate the firing position of #1
- Quick check (skis, boots, poles) and let her rip
- She fired up within 10-15 seconds, hooked up the the timing light and dialed the timing to about 10* BTDC
- Let her warm up... great oil pressure... temp stabilized at 1/3 up the gage after 10 minutes or so
- Hooked up the Tach and Dwell meter, did the first pass on the carb adjustments
- Sounded better than the 2F in the 77 FJ40, almost no valve noise at all compared to my sewing machine, what a thrill...
*** then all heal broke loose after about 20 minutes at idle with the occasional goose of the throttle. It was a popping or banging noise somewhere in the lower block back by 4,5, or 6 ... so I shut her down. After checking everything we could find on the outside and below I fired her again, started effortlessly but there was the noise again, and you could feel it inside the rig. Im at a loss since the start and run went so well. Things I know:
1. The clutch system has not been touched, needs a bleed at minimum. Truck was in nuetral for all of the above so I dont think that it was the clutch.
2. This thing has been sitting for years, maybe an oil passage was blocked and we burned up a bearing?
3. Maybe we lost a wrist pin or connecting rod, but it still ran even with this noise
George has tossed in the towel so I'm going to buy her and drag her up the street, don't tell my wife. Thinking of dropping the oil pan to have a look, thoughts? I haven't built one of these old motors, how hard can it be? I'll make sure I don't do anything FJ40Jim's customers have done in his thread in the 40 section.
