EGR Temp Sensor Test Plug (1 Viewer)
i purchased this kit a few months back. Installed it about a month ago and it works flawlessly. Good Job on the product!
Glad to hear. Thanks for the update!
LC4LIFE - I just checked the link that you provided to purchase a test plug and the 95-97's are out of stock, when do you expect them to be available again for purchase?
Good timing. Just built more up today. Site is updated.
Thanks for the interest!
David
What is the benefit of EGR delete? I have a 95 about to hit 200k and want to take preventive measures to have it running tip top. Any help or info would be awesome.
Defeat the egr code is why I did it. P0410 I think without having to replace all kinds of parts
There are a variety of reasons, some people will dispute the reasons, some will not.
Main reasons for disabling are not cooking the wiring harness next to the EGR piping, to stop dumping hot exhaust gases into #6 cylinder, and/or to defeat the code.
EGR codes are P0401 and P0402
Does the kit you sell come with directions to do the whole delete?
I have rerouted my vacuum hoses and installed the plug and the has been the extent of what I needed other have removed the EGR valve and blocked it. I can send you pics of my setup if you would like.
Let me know
I would be interested to see a set up of what I'm gonna be getting into. Thanks
Here they are. I did this to defeat P0401 code
The ports for these were blocked off I didn’t remove the temp sensor even though LC4life included the Allen plug. Let me know if you have questions I’ll answer as best I can
I wanted a more factory look, so no. It will disable it though. I don't like things being looped around and looking like its been messed with. My kit allows for a nice, discrete factory look.
The ports for these were blocked off I didn’t remove the temp sensor even though LC4life included the Allen plug. Let me know if you have questions I’ll answer as best I canView attachment 2128056View attachment 2128057View attachment 2128058View attachment 2128059
Cracks like this cause leaks, that's no good. Id fix that. It looks like the wrong size cap.
