EGR Temp Sensor Test Plug
Status
Not open for further replies.
I just placed an order for the 95-97 EGR plug. I see you are on vacation. Enjoy your time away. Thanks for all the great posts and research for this. I look forward to installing your product.
So I understand, this kit is all I need to delete egr but keep in place? Also, pipe next to the wiring harness is cool and non functional once installed? I ordered the kit yesterday, just trying to do what I need to get rid of it and the heat by #6 cylinder
Yes. But the pipe will not be cool because of heat transfer from the engine itself.
Thank you. The pipe will be cool as in not being used? I don’t like it’s so close to my wiring harness. Is there any truth to that heat being the cause of head gasket failure by cylinder 6? So I need to remove the whole system?
Speculative truth, yes. Hard proof, not so much.
Is there any truth to these two comments? (See pics) I cropped their screen name out.
Thank you. I was hoping the delete kit would make that pipe next to the harness inop and therefore not be hot other than radiant heat from the block being close.
It helps with that for sure. If you’re really worried about the HG, do everything you can to never overheat too.
Status
