EGR Temp Sensor Test Plug
Status
Not open for further replies.
Started assembling more tonight. Waiting for some more of the allen plugs to arrive, then I will be posting up the updates along with the additional pieces and info you will get in the kit.
OBDI and OBDII are all back in stock and ready to ship. Now you receive the test plug, vacuum line plugs, the allen set screw for the intake manifold along with detailed instructions. Visit my new website to purchase and I will send it on the way.
HuddExpo Land Cruiser
Thanks,
David
Ordered Thanks!
Owned my FJ80 4 weeks, and the 0401 just popped on.... So glad I found this!
ORDERED!
Took me longer to eat the supplied root beer sucker than it did the install. It’s been installed for 2-3 weeks, seems like my throttle response is slightly better at best, otherwise I can’t tell the difference. Hopefully it will increase the longevity of my cruiser.
It's weird that mine actually turned off by itself today? I'm sure it's not gone forever so I'll still be installing it when it ships.
@LC4LIFE - hoping you might be able to shed some light on this: I purchased my '94 FZJ80 OBD1 a few months ago and recently I've been trying to fix idling and misfire issues. The previous owner removed the EGR & PAIR systems. Today I noticed that my EGR temp sensor connector had a wire bridging the two poles. Out of curiosity I removed the wire and went for a drive. The misfire seems to be gone now (but still plenty of idling issues).
Any reason why the previous owner used a wire? Is running it with no resistor okay? It definitely seems to be.
OBDI does not need a resistor in place of the temp sensor, only a jumper. If the wire was bare, or unnecessarily grounding then that could cause an issue, but unlikely. At some point, I would expect a trouble code since the jumper was removed.
Okay. Well I tried ordering a kit from your website but it's not working when I go to checkout. I'm on my iPhone, but even requesting desktop site didn't work.
Not sure on that one. Sold three just a bit ago and I just checked it and it appears fine. Give it another try and if not, PM me your info and I will get it handled.
Status
