Hi
- It appears (if its legal in your area or if your rig is off-road-use only) that you can simply block off the EGR system with block-off plates and plugging/removal of vacuum control lines without affecting any engine functions. Correct?
- It appears that you can simply short out the sensor line going to the EGR temp sensor on BOTH OBD1 and OBD2 vehicles and the Engine Controller will be none the wiser (It will simply see "high" temperature on the EGR all the time, and that apparently isn't a problem). Correct?
Are #1 and #2 above correct? If not, where am I wrong?
Thanks,
Muddy1
1. No reason to go to the trouble of removing it or a block off plate. As long as the valve is closed, just remove the vacuum line to the EGR and it will accomplish the same thing for a lot less work. It is easier to restore back to normal if you need to sell it or register it in another state.
2. No. Most people use a 5K to 10K resistor to "fool" the ECU. It is controversial whether it is a good idea to fool the system into thinking the EGR is working. Normally the ECU leans the mixture out during low load, high speed cruising when the EGR is open to lower combustion temperatures and increase fuel economy. With the EGR not functioning, the mixture will be lean and the ECU will need to rely of the O2 sensors to keep the AFR in the stoichiometric range by adding more fuel via adjustment of the long term fuel trim. The potential problems are that there may not be enough range in the trim table to fully compensate. Clearly, adding fuel is not good for your fuel economy. The EGR is also claimed to increase fuel economy by several % by reducing pumping losses at high speed partial throttle operation. The other potential problem is that the increased combustion chamber temperatures increase pinging, relying on the knock sensors to pull timing to prevent knock. This is widely discussed on the net, so Google it. It seems unwise to risk these problems for no gain and a loss of fuel economy.
