EDIC problems
All you need for the OI is a small pivot near the IP , so you can use a cable instead of a rigid rod, when you pull the cable, the lever is pushing on the " over injection "
A carburator spring can be hooked to the lever to make the pull knub spring loaded
But, is the OI doing something different than the gas pedal?
Hi this topic below might explain more, I think over inject gives more fuel, not more air like throttle (very noticable when glowers are worn, the over inject just cools the bad glowing and more smoke with no or bad starting)
