- Thread starter
- #81
No pictures to add at the moment but Rubithon Prep has been going about as well as it could go living as far away from the cruiser as I do. I live and work in the Bay Area and the cruiser stays at my parents house 3 hours away. This leaves weekends to work on it and Monday-Thursday to order parts. If I could tinker each day after work I think I would have been done by now but that is not the case so the crunch is on.
Did a bit of a tune-up via quadrajet and fresh plugs. Q-Jet should give me some better off camber performance and allow me to hold off on fuel injection a bit longer. I survived last year running the edelbrock carb but definitely not ideal.
New heavier wall driveshaft and ujoints from Driveline Service of Fresno. 1 day turnaround was great as well. Dropped off in the am and ready by 3pm. The cruiser runs down the road 100 times better now with fresh joints and no dents/candy cane striping.
The cruiser has had revolver shackles on it forever and even though the internet makes it seem like they will unload at any given moment causing me to crash and kill a bus full of nuns.... I don't really mind them. Are they the reason these leaf springs break? Maybe. Regardless I didn't feel like changing much up for now and someone local had a set new in the box so I snagged them to replace the hammered and bent ones currently on the truck. The shiny black shackles hanging out the back look a bit out of place but they will fade like everything else soon enough.
Pulled the trigger on a MORRFlate Kit as well so I'll finally have some on board air. Other trail repair items I have been working on include the premier power welder. This thing had a premier from the mid 90's and the alternator portion of it died around 2016. I have just been running a basic gm 1 wire since then (this means no welder) so I sent the welding unit to premier to have them test it before going in on a new alternator.
I have a rear axle rebuild kit I am considering doing before the trip but that could probably be put off. That is not much of a priority right now. Higher on the list is just an overall nut and bolt check, fluid check, collecting my trail spares, and getting my leaf pack down to betts spring to work on getting a new spare main made. I also need to find out if I still have a stash of old knuckle studs laying around or else I'll buy some fresh ones and my current ones can be retired. I gave me easy to grab studs/washers/nuts and bearings away at Rubithon last year to someone who needed them much more than I did.
I'll be back to work on the cruiser this Friday. I'm thinking this is my last weekend to figure out if there is anything else needed to order as the following weekend I will be in Tahoe visiting someone who is hiking the Pacific Crest Trail. So this weekend and the weekend of the 22nd will be my final prep days....
