Wanted Early 100 series: In tank OEM Fuel pump wiring harness
Bomar
Hot Springs, AR
  1. 100 Series
  2. LX470
Arkansas United States
It is a short harness that clips to fuel pump and then the fuel suction plate assembly.
My truck is a 1999
the float is wired in along with the harness, the wires are soldered to the sender from a 98 LX
I am not sure we are talking about the same thing. I understand what you are saying but the wiring harness I need to replace is the short one I circled the ends too.
I need the 2 wire harness I circled because I had to cut it to put an after market fuel pump in.
They were odd colored wires.
I can’t find the part number anywhere.
I'll look at it again tonight when I get home
I was able to look at it last night.
I was wrong, I was thinking the plug in the top of the unit was a 5 wire plug, turns out it is a 3 wire plug and a 2 wire plug.
2 wire for the pump and 3 wire for the level guage
you just need the 2 wire from the top to the pump?
Yes the 2 wire that has the white/off white clear plug at top and the black end to pump.
Shoot me a DM for what you want for it.
If you don’t want to split it up I understand.
$50 mailed to you for the harness
