Driver side noise troubleshooting
Try removing the ring and see if the sound changes. Mine had markings on the back as though they have been moving around slightly on the wheel.
Also these forged wheels can fail.. especially if powder coated. Though if a crack was forming I'd expect some air loss.
Check the usual stuff.. how flat the mounting face is, condition of lug seats, whether any of the lugs tighten at a different rate than the others (if one feels "soft" it could be a sign of bad stud/lug/something)
That answered my next suggestion/question.
If you moved various wheels to that corner and only the one makes the noise, then that should rule out the CV, and rule out the bearing, since those would sound no matter which particular RW was there.
What I wrote was worded poorly.
I was trying to say that I've rotated 3 times and the noise stays at driver front.
I do have one or 2 rings that's rattle even when fully tightened, but the noise should have moved locations with tire rotation.
Wheels have never been powder coated, just beat up a bit on trails. All lugs seat perfectly thankfully.
I'm leaning towards being temperature related, as the more I think back to it the noise is always there in the summer then when fall comes around I stop hearing it and forget about it before swapping the stock rims on for winter. Come back to RW when weather gets nice and noise comes back.
Thinking of this as my plan of attack let me know if I should move the order around:
1. Chassis ears from a friend to see where the noise is loudest
2. Depending of where noise is, swap back to stock rims and test again.
3. While doing tire swap, check for play and closely examine RW in case something is hitting that I can't see the markings of while rim is on car.
I'm hoping for more cool days between now and then to see if in fact it is ambient temp related.
Ah. Ya, I read that to mean it only happened with that particular wheel. It’s an interesting problem….but gotta be annoying as heck... :bang::rolleyes:
Maybe the brake pad is loose?
Does it go away as soon as you touch the brakes?
Nope. Noise is still there when on the brakes
Dumb thought, have you looked to make sure the mud/dust covers for the engine bay are solidly attached? I had a similar issue on my 2008 Tundra a while back and after a long time or searching, found two of the attachment grommets missing... Probably not the issue, but sometimes a long shot wins the race haha
I'm guessing that also.
Agree on checking the RW ring. Mine was loose and I got a repetitive sound that sounded like a wheel bearing.
Yea those things are solid and even having someone else ride with me to make sure we track the noise to the driver front wheel.
There's one that barely rattles but tire rotations proved that isn't the cause as the noise hasn't followed that wheel.
have you pulled the front ABS sensor? Any crap on it?
I have not. I have been waiting to get some chassis ears before buying a CV or anything drastic.
Did not think about checking that. Thanks
Parking lot drive in a circle full lock one side and then the other. The CV should be much more distinct. I have had another driver do it while I stood outside to isolate noise.
I am still thinking it is the dust plate... maybe hitting that wheel weight?
If so maybe they can move the wheel weight?
If it is the weight, then weight should have a shiny mark.
The 2nd video shows something brushing each rotation and the weight looks shiny on the leading edge.
Have time today to dig into this issue more.. Was checking if anything is loose. Can move the CV input to front diff in and out a bit on driver side can't on passenger. Assuming this is not good news. I've attached the video as well.
Also going to be throwing chassis ears on later today and going for a quick drive, but assuming I need a new CV?
@bloc @linuxgod @TeCKis300 @grinchy I believe all of you have removed your wheel speed sensors before. FSM is saying I need to disconnect the battery first and all that. Question for you is can I just unplug the connector to the senor and pull the sensor out while leaving the battery connected? Or just follow the FSM and disconnect and wait, any other concerns that I should worry about when pulling it out?
The Chassis ears I borrowed were not working. I was told they don't always work, but it was worth a try. I had the sensors attached to each tierod up front and both sides of the diff. Then moved to wheel speed sensor on both sides and steering stop. At one point I could hear a faint rotational noise on driver wheel speed sensor.. Next step is take the sensor out and see if there is markings.
Same, didn't pull the batt.
With ignition off there shouldn't be any issue DCing ABS sensors. Airbag ignitors, different story.
Wheel speed sensor is perfect. No play in the wheel. Slightest amount when hands at 3 and 9 on wheel. Looked back that little play is where the tierod connects to the knuckle and is the play in the bushing.
What's the next thing I should be looking at? No rub marks anywhere to be found to say that's what's making the noise
I think it was said, but wheel hub could be bad. I just had two hubs go bad on my car and it was an easy swap (similar scenario to you). Do a quick YouTube search for bad wheel hub/bearing and it might give you an exact representation of your symptoms. HTH
