Sounds like we should all verify if our physical lock works. I don't think I've used mine in nearly four years of ownership.
I was thinking the same thing, so I checked the function of the mechanical key on my 2013 LC200 and found something interesting:
As per the manual, when I turn the key to the right, doors unlock. No problem.
However, the manual says when I turn the key to the left, doors should lock... but... NOTHING HAPPENS!
So, mechanical key unlocks doors fine, but I am unable to lock the doors with the mechanical key.
It's not a big deal - if I want to lock the doors I just open the driver's door, press the door lock button, and close the door - doors locked, no problem.
But, I am curious whether I am the only one to experience this? I purchased my 2013 LC200 new, and no work has ever been done on the door.
Thoughts?
HTH
I just drilled and tapped my SPC UCA's for grease zerks just recently and remembered there is a wire bundle just in from of the bolt head and in the way when you want to remove the long bolt.
Wait for it...ok, now try the button.
