Donkey BUILD UP
Looks like a Ranger Torque Splitter from Advance Adapters. Either over or under drive depending on what he ordered. Just my guess.
more photos
Could you tell me how long the drivetrain is? Bellhousing to rear flange...
Thanks,
Jay
All together, the drive train measures 37 3/4,
the Australia 5-speed + 3 1/2,
the Ranger Torque Splitter + 7 1/2,
in my case, I moved my transfer case 2" forward,
it means I have to shorten my front drive shaft.
Is that an SM465/ranger combo drivetrain?
how's it sit in respect to rear driveshaft length?
Did you bump the engine forward to compensate, hence the rear-mounted radiator?
,it is a new H55 Transmissione and a Ranger Torque Splitter (Overdrive),
I have moved the engine so far forward, the Water-Pump-Pulley
is there where normally the Radiator is,
I moved my transfer case 2" forward to, I almost run out of space,
I think I need some kind of bar in my garage.
A refrigerator with a lot's of cold :beer:
It would make it much easier to go down there and work.
Suggestions?
Hi
, moved into my new workshop and had no time to work on my FJ40. Once everything is in place it will go on.
Someone uses a low-oil-pressure-switch-off?
How did you do the wiring?:hhmm:
Some do it and then some do it right. Your definately doing it right
