Does the plastic under the hood of a LX570 do anything?
Discussion in '200-Series Cruisers' started by jafo9, Apr 8, 2015.
  1. jafo9
    jafo9
    206
    19
    Jan 13, 2010
    I just changed the air filter and the cabin filter (thanks beno) on my wifes LX570 and I realized that it took longer to get the plastic cover off than it did to change both filters. It looks like there is a hood seal on the leading edge of the plastic covers. Does this perform any function or can I ditch the plastic covers? Do the LC's have this stuff as well?
    chipsterguy likes this.
  2. MScruiser
    MScruiser obsessive-compulsive oppositional-defiant wise-ass
    5,457
    Media:
    206
    Albums:
    1
    6,017
    Jan 3, 2012
    Jackson, MS
    If I am understanding your question correctly, yes, the covers/seals are important, as they help with the fresh-air/recirculation system. But, I may have misunderstood what you were talking about.
  3. Archtaan
    Archtaan
    333
    246
    Aug 21, 2012
    Idaho
    If you are talking about all of the extra plastic covers in the engine dept that the LX gets over the LC, then no. Its there to pretty it up.
    LX vs LC engine bay.
    Stumpalama likes this.
  4. Stumpalama
    Stumpalama Forum Junkie SILVER Star
    6,389
    1,785
    Nov 5, 2004
    NOVA
    WTF! That plastic is ridiculous!
  5. bdac
    bdac
    283
    133
    Apr 10, 2003
    Frederick, MD
    To remove the plastic pins you just press the middle indentation and pull the entire screw assembly upwards. Should take only a few seconds. Don't pry them or you'll break them off.
    89cruiserfj62 likes this.
  6. Rigger
    Rigger Ramble Tamble Staff Member Moderator
    4,639
    Media:
    4
    Albums:
    1
    1,717
    May 18, 2007
    Wyoming
    X2. Remove all that stuff. Put it out behind the garage.
  7. jafo9
    jafo9
    206
    19
    Jan 13, 2010
    maybe my pins are worn out, they don't pop out easily at all. i have to pry the whole plastic sheet up and then try to catch the pin as it pops out. its kinda fun when you do it with a beer in one hand.
    DirtNap likes this.
  8. SpillmanCruiser
    SpillmanCruiser
    339
    10
    Mar 10, 2008
    Baton Rouge
    I now have something to do to my new 200. The plastic will be gone before long. Can't see crap in the engine bay.
  9. SWUtah
    SWUtah
    4,363
    772
    Sep 16, 2005
    Ponte Vedra, Florida
    It's a special shield that prevents hackers from taking control of your vehicle and then stealing All your personal information. Just saying
    DirtNap likes this.
  10. skhochay
    skhochay
    589
    Media:
    1
    Albums:
    1
    134
    Dec 13, 2012
    Idaho
    if you want to get the plastic off I want it
  11. rrclx
    rrclx
    51
    Jan 24, 2007
    It keeps everything nice and clean inside the engine compartment. It likely lowers noise.
  12. LCHardriver_02
    LCHardriver_02 SILVER Star
    2,225
    495
    Jan 18, 2008
    Boise, ID
    I was thinking of ditching this as well. Mine is missing some of the little fasteners that hold the panels in place. I too like to actually see my engine. ;)
  13. SWUtah
    SWUtah
    4,363
    772
    Sep 16, 2005
    So you use a screw driver push in and turn, then the assembly pops upwards? Just use your fingers and remove the pin assembly and lift off the plastic covering for that panel. To put back just do this in reverse. Am I close to right?
  14. gaijin
    gaijin GOLD Star
    1,561
    1,131
    Dec 9, 2012
    I don't think so. I have an LC, not an LX, but I think the pins being talked about are the same. There should be an explanation in your Owner's Manual similar to this:
    [​IMG]
    To remove a pin, just press down on the center part and lift the poin assembly out.
    To re-insert a pin, first press the center part up beyond where it was originally, insert the assembly into a hole, then press down on the center part until it is flush with the top of the assembly.
    No tools required.
    HTH
    allan man and SWUtah like this.
  15. SWUtah
    SWUtah
    4,363
    772
    Sep 16, 2005
    Thanks used the above post and tried it out, works great very easy to take off and put back on.
  16. JeffH
    JeffH
    79
    22
    Sep 22, 2015
    Littleton / Fairplay, CO
    Anyone know a source besides Lexus for the pins that hold the engine covers in place? Or are they actually reasonably priced from Lexus :)
  17. Lexus68
    Lexus68
    23
    2
    Jan 29, 2016
    New York
    I bought a bag full at my Lexus dealer. I don't recall the exact price but they were not expensive.
  18. Ali FJ80
    Ali FJ80
    807
    746
    Sep 1, 2005
    Denver
  19. dnh1
    dnh1
    301
    Media:
    1
    Albums:
    1
    290
    Mar 19, 2009
    That's what its there for
  20. TeCKis300
    TeCKis300
    1,217
    Media:
    1
    727
    Apr 27, 2011
    It does 2 things:
    1) Lexus has higher standards for acoustic attenuation. The engine cover, and covers along the engine bay, significantly dampen and reduce the sound coming from the motor. Especially at idle, where you can hear the injectors and such.
    2) Beauty cover. Toyota manifolds definitely veer on the side of functionality and maintainability rather than classically beautiful as older V8s. You'll find lots of plumbing and electrical plugs/harness on top of the motor.
data-matched-content-rows-num="2,1" data-matched-content-columns-num="1,4" data-matched-content-ui-type="image_stacked" data-ad-format="autorelaxed">
