- Joined
- Jun 6, 2005
- Threads
- 74
- Messages
- 1,395
- Location
- Jacksonville Beach, Florida
- Website
- exitoffroad.com
Alright guys and gals, Dobinsons have answered all the requests and made a 3-way adjustable front shock option for the 100 Series. Adjust high and low speed compression and rebound on these bolt-on external resi front shocks.
Available in 2 lengths:
MRA59-A782 - MRA replacement shocks for up to 2" of lift
MRA59-A786 - MRA Extended length replacement shocks for 2-2.5" of lift - these require aftermarket UCA's like the Dobinsons UCA's as well as a Diff Drop Kit for full articulation/droop and no CV binding. The Dobinsons UCA's have a rotated ball joint cup so that more droop is achieved with a set of 555 sealed ball joints.
Available now at ExitOffroad.com
exitoffroad.com
exitoffroad.com
And to complete the post, the rear shocks that have been available for a long time are here:
exitoffroad.com
More photos to come soon. Standard product photo shown below for now.
- 3-way adjustable valving – Adjust high and low speed compression and rebound
- Massive 66mm (2.6″) Outer body with 60mm (2.36″) Bore and Piston
- 3-way Adjustable shocks provide maximum adjustability to provide the perfect ride quality for you.
- 10 Stage High Speed Compression – For aggressive, high speed off roading through ruts and holes.
- 20 Stage Low Speed Compression – For creepy crawling and cornering
- 15 Stage Rebound – Control your coils, prevent bucking
- 60mm CNC Machined High Flow Billet Aluminum Race Piston
- 3mm Thick Heavy Duty DOM Seamless 66mm O.D. shock Body Precision Honed to +/- 0.04mm
- Upgraded 3 Stage FKM‐HNBR Sealing System
- TSUGAMI™ CNC machined components for precise tolerances
- Parker™ Braided High Pressure Hoses
- 5140 HV900 Hard Chrome Plated, Heat treated 18mm Micro-Polished high strength Shock Shaft with a minimum tensile strength exceeding 700MPA
- T6 6061 Height Adjustable Spring Seat
- Carbon-Fibre/PTFE/Disulphide composite wear band for the ultimate in low-friction, low‐wear performance
- 60mm Full 6063 aluminum remote reservoir
- Lightweight CNC Machined Low Friction floating piston
- High Quality O.E.M. Grade Natural Rubber Bushings
- Single Piece Lower Leg
- EDP Surface Protection
- CNC TIG Precision Welded Body End Mounts
- Fully Rebuildable Design
- SOLD IN PAIRS
- Includes Reservoir Bracket and Hardware, Sticker Pack, and Adjuster Wrench
- Reservoir mounts to the empty holes forward of the shock on both sides
- Full 2 year limited warranty, no set rebuild time period
Dobinsons MRA59-A782 3-Way Adjustable MRA Front Shocks
Dobinsons MRA59-A782 3-way adjustable front shocks for Land Cruiser 100 Series 0-2" lift, high/low speed compression and rebound adjustment
Dobinsons MRA59-A786 MRA Extended Travel Adj Front Shocks
Dobinsons MRA59-A786 3-Way Adjustable (compression and rebound) extended travel front shocks for Land Cruiser 100 Series from 1998-2007
Dobinsons MRA59-A682 3-Way Adjustable MRR Rear Shocks Pair | 0-3" Lift
Dobinsons MRA59-A682 3-way adjustable rear shocks for Toyota Land Cruiser 80, 100, and 200 Series, adjust high/low speed comp and rebound
