- Joined
- Jun 6, 2005
- Threads
- 74
- Messages
- 1,392
- Location
- Jacksonville Beach, Florida
- Website
- exitoffroad.com
Hey guys, breaking down all of the current Dobinsons options for the 100 Series and LX470, putting it all in one place. I keep seeing various questions in various posts all throughout here about what options there are, so hopefully this can help some of you out when the time arises.
All parts are available separately, and there are also kits available with the options to pick and choose what parts you want as well.
Torsion bars
TB59-1600 - For gasoline V8 models - Heavy duty, increased rate. 1160mm length. Can be used to replace AHC or standard torsion bars.
TB59-1610 - For diesel and turbo diesel models specifically - Heavy duty, increased rate. 1210mm length (these cannot be used on a V8 Gas model)
Front Shocks - Gas and Diesel Engines
GS59-782 - Twin Tube Nitrogas Shocks - for 0-2" lift
GS59-786 - Twin Tube Nitrogas Shocks - for 2-2.5" lift - extended length so that shock doesn't max out too soon with taller lift heights
IMS59-60782 - IMS Monotube Shocks (internal resi)- for 0-2" lift
IMS59-60786 - IMS Monotube Shocks (internal resi)- for 2-2.5" lift - extended length
MRA59-A782 - 3-Way adjustable Monotube remote resi shocks - for 0-2" lift
MRA59-A786 - 3-Way adjustable Monotube remote resi shocks - for 2-2.5" lift - extended length
Front Upper Control Arms (UCA's)
UCA59-006K - Heavy Duty pair of upper control arms, ideal for lift heights up to 2.5" of lift, allowing for better suspension movement, and wheel alignment due to built-in fixed caster. Comes with Sankei 555 Ball Joints (made in Japan), OE style rubber bushings. Zero maintenance required.
Rear Upper Trailing Arms
WA59-555K - Fully adjustable, OEM quality rubber bushings installed, 5mm wall thickness tubing, zinc plated and powder coated
Rear Lower Trailing Arms
WA59-551K - Fully adjustable, OEM quality rubber bushings installed, 40mm OD and 6mm wall thickness with support brace, zinc plated and powder coated
Diff Drop Kit
DD59-532K - Complete front diff drop kit to lower the differential when lifting 2" or more and correcting the CV angle, and also allowing for the longer travel front shocks to be used on conjunction with new UCA's
Rear Coils - lift height is of course subject to replacing stock/worn out components, and AHC vs non-AHC systems.
C59-169 - 1.0" lift, linear rate, with stock weight inc 3rd row seat, 1.5" without 3rd row. For slightly above OE stock height. Ideal if someone is doing AHC removal but doesn't want to add much lift (465/475mm free height, 227LB rate)
C59-223V - 1-1.25" lift, variable rate, with stock weight inc 3rd row seat, 1.75" without 3rd row. Closest equivalent to C59-169, but variable rate for more comfortable ride quality and low lift height (445/455mm free height, variable rate).
C59-167 - 2" lift with stock weight inc 3rd row seat, 1.5" lift with 150-220LBS constant rear weight, linear rate (485/495mm free height, 227LB rate)
C59-185 - 1.5" lift, linear rate, with 440LBS constant rear weight (480/490mm free height, 277LB rate)
C59-171 - 1.5" lift, linear rate, with 880LBS constant rear weight (485/495mm free height, 328LB rate)
C59-175V - 2.5″ lift with up to 220lbs constant Load
Rear Shocks
GS59-682 - Twin Tube Nitrogas Shocks - for 0-2" lift
IMS59-60682 - IMS Monotube Shocks (internal resi) - for 0-2" lift
MRA59-A682 - MRA 3-way adjustable monotube shocks with external reservoir - for 0-2" lift
Longer shocks are available for those wanting to do a longer travel rear end - PM for more info and specifics.
I know some guys have tried different Dobinsons 80 series rear coils in their 100's, based on different heights they were looking for, or heavier rates. If that someone is you, please post up a summary of what you've used and what lift height you've got with whatever load you're carrying so that I can add those to the list.
Torsion bars
Diff Drop Kit
Rear Shocks
