I've found that amount of rake rides well on my Tacoma and the 100. That is ideal as far as my experience goes.
yeah I have turned the T bars once more since then because it was a lot of rake, but I'm also hoping the rears will settle a bit.
They will.yeah I have turned the T bars once more since then because it was a lot of rake, but I'm also hoping the rears will settle a bit.
I would bet that would be sky high. I’ve got the 185s with a pretty heavy truck and sits pretty high as it is.Has anyone tried a c59-309 on a 100?
Same spring rate as the c59-185 but a bit more height.
I’m currently running the C59-167 with 15mm spacer, airbags and IMS shocks. I’ve been considering going moving up to the 185 and maybe even 171. I’ll be adding a cruiser company rear eventually too.
I think the 171 will be way too stiff though. I’m thinking I could get rid of the spacers with the 309.
- Suits Land Cruiser 80 Series and Lexus LX450
- C59-309 4″ lift with 110-220lbs weight
- 520/530mm free height, 20mm wire, 274LBF/in rate
View attachment 3913492View attachment 3913493
Since you don't have hardly any weight on it now, I wouldn't go with those. 80 series coils fit on a 100 series, but they don't lift as much because the 100 series is heavier.
The C59-167 is what I'd suggest. They'll be 2" with a 3rd row seat or light weight and 1.5" with the rear bumper. You can add rear spacers to boost the rear height later if/when you add the rear bumper, or change out the springs at that time. If you get 2.5" springs now to suit the weight, but you don't have the weight on there, you'll get like 3-4" of rear lift and it won't work out so well.
Dobinsons LX470 + 100 Series Land Cruiser 1998-2007 Rear Coil Spring Options - Pair
Dobinsons 100 Series Rear Coil Spring Options - this page combines every possible rear coil option for the 1998-2007 Landcruiserexitoffroad.com
C59-175V give 2.5" of lift with 220lbs added on and behind the rear axle. Sounds like you're probably 300lbs with the bumper and tire on the back. So you'd probably be 2-2.25"Hey Mike,
I'm wondering how much lift I'd be getting with your C59-175V coils. Is there a formula of some sort Dobinson's uses?
I have a Dissent rear bumper with a tire swingout + 35in spare, aluminum skids, rock sliders, steel TJM T17 front bumper + winch, no 3rd row seats.
How do the springs do paired with Dobinson's IMS shocks? I'm currently running Bilstein B8 5160 shocks and SOF2RH Slee Rear Coil Springs, which is too stiff and jarring for me, especially on the crappy Los Angeles streets, which have potholes, bumps, dips, and cracks everywhere.
Thanks,
Daniel
Great, thanks. So I'm leaning towards the extended travel shock. Will I need to extend my brake lines and add bump stops? Any other modifications I might need to make?C59-175V give 2.5" of lift with 220lbs added on and behind the rear axle. Sounds like you're probably 300lbs with the bumper and tire on the back. So you'd probably be 2-2.25"
You add up how much constant added weight you've got, then choose a spring that suits that weight range and the lift height that you want.
I've never ran these springs myself, but they're not a very high spring rate, so they would ride quite comfortably, and the ride of the IMS shocks has proven to be very good on and offroad.
If you run longer rear shocks than I have listed in the first post, then yes, you'll need to extend brake lines and bump stops. You'll be trading up travel for down travel, so unless you're rock crawling the cruiser, it won't be very beneficial to add that extra down travel, and to limit the up travel.Great, thanks. So I'm leaning towards the extended travel shock. Will I need to extend my brake lines and add bump stops? Any other modifications I might need to make?
Got it thanks!If you run longer rear shocks than I have listed in the first post, then yes, you'll need to extend brake lines and bump stops. You'll be trading up travel for down travel, so unless you're rock crawling the cruiser, it won't be very beneficial to add that extra down travel, and to limit the up travel.
Not my site. My site says this:Got it thanks!
You mentioned that the 175V’s are a softer spring… I’m now considering the 185’s. Thoughts? With a constant load of 350lbs behind the rear axle, what amount of lift am I looking at? Your website says 2in at 440lbs, but I’d be a tad lighter than that.
Interesting. Why the discrepancy? Any way you can estimate how much lift I’ll have with the C59-185’s given 350lbs of constant weight? Seems like there should be some sort of formula to figure this out so we don’t have to bother and ask.Not my site. My site says this:
Same info as on the first post of this whole thread.
- 100 Series and Lexus LX470 (1998-2007) – Dobinsons C59-185 – 1.5″ lift, linear rate, with 440LBS constant rear weight
With less weight than listed, you'll get more lift.
I looked and I don't have any other installed photos saved. I would still recommend the 105 series position from the instructions.Long time lurker here, love all the information on this forum. I just installed Dobinsons MRR shocks on all 4 corners (thanks ExitOffRoad for the Black Friday sale) and I am having a heck of a time finding the correct position for the remote reservoir in the rear with the piggy back mount and I cannot find any images of where people have mounted these on the LX470/LC100
If I mount it following the LC105 instructions, I am fairly confident it will contact the LCA and Sway Bar. I currently have it mounted near the top of the shock body, facing the driveshaft, parallel with the spring. This gives me 7 1/2" of travel before the LCA could contact the reservoir, but measuring axle to bump stop is also 7 1/2" which concerns me that I could potentially make contact with the reservoir at full stuff. Anyone have pictures of their setup?
I will be trying to find some ditches and loading docks to test it out on, but wanted to see other's setup as well.
TIAView attachment 4041205View attachment 4041206View attachment 4041205View attachment 4041206
