Dang, get busy w/work and leave you guys alone for a week and all of a sudden my post is 9 pages deep!
Anyway, here is my current dilemma. I removed the clamp, got is straitened out and it will tighten down/is working correctly now.
However, when I follow the procedure for setting static timing in the haynes manual, I can't get the truck to run correctly.
I have the mark on the flywheel set, and the oil pump shaft set aprox. at #4. When I do this, it puts the rotor in line w/either #4 or the PS fender, because the rotor is in line with the oil pump shaft. When I alter the position if the oil pump to point the rotor to #1, then all I get is flames out of the top of the carb. From there, I tried rotating the flywheel 360, but then it does nothing, just turns and turns(read: leave dizzy in, rotate to #1/flywheel mark, pull dizzy, rotate crank 360 back to flywheel mark, re-stab dizzy)
I did get it seated pointing more towards #2 than one, and it would run, but I had to feather the gas the entire time to keep it from dieing...tried just clocking it back towards #1 a little(i.e. one cam gear or so back)and nothing.
So...what am I doing wrong guys? I know that I am out of timing, because when I had it set the first time, it purred.
Oh...and please keep the "why didn't you just leave it where it was" comments to a minimum. I don't know why I messed w/it. :-[
Thanks,
Ryan
