Feel like I’m pointing out the obvious here, but why not buy 2 5QT jugs? They are cheaper at Walmart as well. You can purchase 3 gallon boxes there now as well for cheapest by volume. ($50/ 3 gallons in my region).This is a very helpful thread - thanks everyone. Although I have included maintenance for my first year, I'll be doing my own oil changes, particularly after hearing about the recirc door breakage risk, torque issues, etc. from the dealership. I've been driving leased vehicles (almost all with included maintenance at the dealership) for probably a decade or more now, so it's been a LOOOONG time since I did an oil change myself. My good friend owns a shop, however, so I'll be putting it up on one of his lifts and using his rolling oil catch pan/container, which should make things go smoother.
While it's up there I plan on removing the protective plate and working the KDSS bolts / hex screws to make sure they're not rusted / frozen. I have a 2018 LC200 - will I have the 5mm allen head (recessed) screws/bolts, or exposed "regular" hex head bolts?
I have the Jowett oil pan drain valve in hand, just waiting on the actual Jowett billet filter housings to come back in stock. Picked up 4 new TRD oil filters from the local Toyota dealership this morning, so all set on that front. I bought 9 quarts of Mobil 1 Extended Performance full synthetic at AutoZone yesterday. WOW that stuff is expensive - I paid $35.99 for the 5 quart jug, and $11.49 for each of the 4 x 1 quart singles. Did I pay too much?
@bloc Just curious, why wouldn’t you recommend extended performance M1? I bought TGMO for my 200 but just put in EP M1 in my 100 LC. So curious what your reasoning is.
Disagree. Lowest paid “tech” with little to no experience and ZERO ****s given.I pay $75 every 10,000 miles for my LX, that includes a tire rotation (bought my tires from the service station) why would anyone do it themselves? My guy does oils changes every day, far better then in your driveway every once in a while??
Thanks for your response. I plan on replacing every 7500 miles (or 12 months), so will go back to a regular synthetic next oil change."Regular" synthetic oil has the requisite base stock and additive pack to surpass the requirements set forth by the companies building engines, let alone an engine that is easy on oil like almost everything toyota makes. Generally when you go much past that you start to get into the "tweaks" that provide diminishing returns and can even start to alter the base of what the oil is intended to do. For instance, without knowing specifically what they do for an EP oil, I'd guess they push viscosity up closer to the top of the range, increase viscosity modifiers to fight shear, and probably push the TBN up to let the oil work longer and deal with contaminants better over extended drain intervals.
Basically, if you are changing your oil often enough, you just don't need these "tweaks".
Another good example would be the "seal swellers" added to some oils intended for high mileage engines. Yeah, in theory it can help seal leaks, but it does so by taking a given chunk of rubber and increasing it's size, which lowers it's hardness, makes it more likely to sustain damage, and some parts you just don't want swelling.
"Regular" Mobil1 or Pennzoil Platinum or any synthetic (or even modern conventional oil to be honest) is pretty incredible stuff. Find any of those products as cheap as you can, change it often enough, and your engine will not be failing any time soon due to lubrication-related issues.
Side note.. does your 570 really only have 15k miles?! Or is that a really old number?
Huh? $6 filter and $40 in oil.I pay around $87 at my local independent Japanese Specialist shop. It would cost me almost that in oil/filter parts alone. They get it done in around an hour and then they go over the truck to see if there are any issues. Plus, I don't have to deal with used oil.
$77 typo. So $46, yes it's not that much. I get people like to do it themselves but for $31 bucks I'd rather have the shop do it. Esp. trying to transport and get rid of 8 quarts of used oil.Huh? $6 filter and $40 in oil.
I’d rather do it myself and make sure it is done correctly, levels are correct, things are properly torqued and all of the parts end up back on the vehicle.I pay $75 every 10,000 miles for my LX, that includes a tire rotation (bought my tires from the service station) why would anyone do it themselves? My guy does oils changes every day, far better then in your driveway every once in a while??
And also stripped front differential drain plugs.MANY of our vehicles have very expensive broken AC recirculate doors based on previous owners using that logic.
I've had the dealer do the oil changes up until now as they were free.
But I'm setting up for my first DIY oil change and I'd really like to replace that plastic filter assembly with one of the Toyota OEM aluminum housings.
Along the way I found that there appears to be 2 part numbers for the aluminum filter assembly.
There's 15620-31060 which I think is the Venza part people are using. I get that it requires that you swap the center screen
And then there's this one, 15620-51010, which appears from the pictures to have a longer center screen. I'm wondering that if the housing fits then it might not require swapping the center screen. Anyone know anything about this part? Is it a drop in replacement for the plastic OEM housing & screen?
Looks like there is a new Fumoto valve that uses a two piece configuration with a banjo bolt.Looks like that second part is for a 4.5 Turbo Diesel. I don't know if it fits, but I'd stick with the cheaper NA market part we all know fits and swap over the center screen. I'm really replying to tell you not to forget to order a new drain plug cap (15643-31050). On mine it had clearly been used to torque down the oil filter cover and was fused to the cover so I was not able to move it over from the plastic filter cover to the metal filter cover. If you know you can remove yours, then no need.
Also this thing is nice and a Fumoto drain valve for the oil pan goes a long way in making an oil change quick and painless.
Amazon product ASIN B08C5F5FQP
