Your fuel pump might not be keeping up with the needs of the carb. It'll show up most on acceleration and under load. Backfire out the carb is consistent w/ that kind of lean condition.
I'm late here--sorry if you already checked that.
The 32/36 is generally regarded as being not enough carb for them.
The stock Aisan 2F carb has 38/40 mm throttle bores, so the idea that it is too much air flow is probably incorrect. More likely a jetting problem.
The screw is only for adjusting the idle fuel mixture. It has no effect when the throttle is opened. To change the running mixture you need to change the main jets.
I'm not a carb hater. There are a lot of different carbs out there and most of them work just fine. The Stock Aisan is a good carb, but it is a little more complicated than a Rochester or Holley.
The screw is only for adjusting the idle fuel mixture. It has no effect when the throttle is opened. To change the running mixture you need to change the main jets..
That's what I am looking for. I still have my old 38 / 38 and going to replace the idle jets to start. The smoke is black at idle, and the fuel mileage from the main jets is around 7 - 9 MPG.iirc i had the smallest idle jets i could find for a 38 38
