In September I had an awful time at the indie near me that is well known for work on Toyota’s and 100’s, but now appears likely they have little to no experience on a 200. I can get into the whole issue about a failure to bleed my KDSS valves necessitating me to correct a lean myself, but that will detract from present issue.
After a really bad experience, I vowed not to go back, so this weekend I took my 13’ with 145,000 miles to local Toyota service department for oil change and coolant exchange. They were very concerned about the color of my differential fluid, which they said appeared red, compared to the clear / yellow / amber of the LT 75W-85 GL-5 which is what they use a recommend.
I just got off the phone with the indie, and they indicate they use non-synthetic Mystik JT-7. Looking at Mystik’s website, they have two non-synthetic Weights 80w-90 and 85w-140. I have to assume they used the 80w, and I guess I should call back and confirm. They seemed confident, indicating they have used the same diff lube for over 50 years.
What are your thoughts? Should I leave this Mystik product in? Redo it?
I realize i should have verified this first, but I guess I was more concerned about verifying they used Toyota WS transmission fluid for the tenant fluid exchange and that they understood the KDSS system and I forgot to ask about specific diff lube.
What should I do? So aggravating that I went to great lengths to find an indie, do almost $2000 worth of preventive maintenance and now have a non/confident feeling in my gut.
