will a 60 series front diff center section bolt into the rear diff of my bj74 ? My rear pinion bearing and seal are giving up on my 74 so Im looking for the easiest fix and I have a 60 series parts wagon I can scavenge from.
so if Im going to have to source a different third member from some one local - which 40 series thirds will work ? I know that the spline count changed as well as ratios in the 40 series just not sure the years.
I have put a 40 series diff in the rear of my 75 before no problems
wongtsenhin said:Do they have the 3.7 ratio small diff for my front 75? Please give me the part no if yes. One more thing, what is the diff ratio for FZJ75?![]()
if there is one, i want it. i would love to have a 3.7 in the pickup. the increase in fuel mileage, top speed and quieter engine would make the swap appealing in my view...
i will check into it.
Doesn't marks 4wd adapters make a kit to drop 5th gear rpm
Maybe you could use taller tyres Wong to drop freeway rpm.
The 3.7s are very popular with those that like to waste $20,000+
on those waste of time overheating slug 6.5 v8 chev diesels conversions in there cruisers.most the 85-89 75 series use diffs from the 3speed 40 series , not sure about post 1990 cruiser owners to what they use , maybe brand new gears.
