Note: This feature currently requires accessing the site using the built-in Safari browser.
From my 05 LX book
Are you sure that this book is for a 05 LX?
Because the Limited Slip is not mentioned, while I assume that these years do have LS (I have an 04)
A (pre facelift) LC books states:
Standard differential Hypoid gear oil API GL- 5
Limited slip differential Hypoid gear oil for limited slip differential API GL- 5
Pretty sure LSD was only on the 98-99 LX. After that, they were the same as LC with an open rear diff and ATRAC.
That is correct Sir.
98-99 LX had LSD standard from factory (U.S. models)
98-99 LC had open rear diff with an option for Electric Locker (U.S. models)
LSD requires a diff lube with friction modifiers.
Sweet! I remembered something! Maybe there's some life left in this old brain of mine![]()
And after 99?
I have an '04
And after 99?
I have an '04
As already stated in post # 5 above........... "open rear diff and ATRAC "
