What area is the 40 in CO? If it is close I may be able to lend a hand.
It is very worth it . Especially if your in the left seat and don't have to fly it .Almost sounds worth it just to ride in the bird!
Well, too late now. I used a very small amount. Hopefully I didn't do any damage. The engine sounds fine to my novice ear -- no pinging or missing. Someone in Denver who owns a 3B adamantly encouraged ether. Maybe he has just been lucky that he hasn't damaged his 3B so far?Some bad advice thrown out here.
Warning never use ether on a 3B....... yes semis use it in extreme cold conditions difference is the 3B has 20:1 compression were a semi is way less compression.
About that "All I can say is-get your truck out of their asap!!! ... They can pillaged and used as target practice. ... do whatever it takes to get it out" consider that to the casual passer by there is no difference between a ":non-starting BJ" and a "parked by an overnight hiker BJ."
I don't wish to start an argument, but if you use an aerosol, don't use the glow plugs and use only a whiff, there is very little chance of damaging the engine. The issue comes when (and I have seen this done) people empty half the can into the intake and attempt to start as usual. Next thing they've got a bent con-rod.Some bad advice thrown out here.
