Now that it's not below freezing here in MA, I've been trying to get out to the shop to get some projects done on my truck.
I took the carb off last weekend, for a rebuild, and posted about that. In the process, I learned I need to replace the oil galley plug: thanks to @John McVicker and @unklwedy for the heads up on that.
Since I'm already into some engine / carb work, I tested the compression today.
Here's what I found, starting with cylinder 6 at the fire wall, and dry / wet testing numbers:
6: 145 / 150
5: 120 / 120
4: 120 / 125
3: 120 / 120
2: 100 / 115
1: 145 / 150
There are two symptoms that lead me to believe I need to check compression.
1; when I was parked on a relatively steep hill, with parking brake engaged (parking brake needs to be tightened), the truck rolled backwards, "pulsing" as it rolled slowly. I was in the truck, and used the foot brake to stop the rolling, but took note.
2; when in 1st gear, foot off the brake, and descending a steep driveway, I get a sound from the tailpipe like backfiring / rumbling. Same thing happens if I let off the gas when going downhill, even in 3rd gear.
So, that's the info that I have. Keep in mind I'm new to wrenching on a 2F.
I'm curious to hear MUD's collective thoughts on what my next best move is. I'm posting some pics of the process, and the 'plugs that I pulled out (clearly need to be replaced, also assuming other issues).
6: 145 / 150
5: 120 / 120
4: 120 / 125
3: 120 / 120
2: 100 / 115
1: 145 / 150
