destins 1964 fj40 FST restore thread
"just painted the brake and clutch pedal arm and brackets, a fresh coat of black "
We want to see more pics :)
OK installed the painted brake and clutch arms with new master boots etc.
Picking up new return springs today at the hardware store.
Oh and yes i DO realize i put the steering wheel column support backwards and on the wrong sided of the dash cowl, need to pick up the red front lower facing brace tomorrow form the paint shop :D
Lookin Great Destin, please do not use that rubber gas pedal pad, Land Cruisers never had Volkswagen parts. Are you keeping that non stock ball as a handle for your front axle drive pull/push lever? If you want a stock one I will donate one to you since you have kept us all on edge with the buildup. Your Coil is upside down. Keep plugging. John Pardi
Hi John!
Thanks man :)
I did not realize my 4wd 2wd button was incorrect.
If you have an extra one and would not mind parting with it I would love to have it :D
I seriously appreciate it man, you still have my address?
I make sure not to put the rubber bit on the gas petal, thanks for that heads up.
The gas pedal should be the same pewter silver as the glove box correct?
Oy I forgot to flip my coil over, hehe thanks again :D
Do any one of you know of an unobstrusive/ stockish looking below the dash oil pressure gauge?
I like to be able to monitor my oil pressure, unless you guys think the stock gauge is accurate.
they painted all the pewter bits, all ready to go!!!!
Looks great!
Shane, let me know when your dude is available to do the seats, ready to go on this end ( I even have all the foam bits for the front seats, need foam bits for jump seats though :D
Will post more s*** later, need to work :D
glove box in
Using one of Shane's plates :)
dark image sorry
blurry image of bumper mocked on
turn signals
torn with using the old worn white lenses or the new ones which are yellow, probably end up going with the old worn ones that are white...
Thoughts?
post up a side by side shot...one white and one white ....we'll let you know which is best....we are very opinionated here :)
i would think white...but...we like pics
Will do :D
Put the fenders and side bits on today so i can adjsut the body properly this weekend ( turn signals included )
I will take photos tomorrow when it is not raining, looks soooo good :D
Putting the front grill together tonight :D
Booya!
def go with the new yellow. IMHO that's the way they were new. There have been some debate that there were clear lenses (I'm not fully convinced) but just about all the lit i've seen indicates amber. BTW those look so good in red.
