- Thread starter
- #281
The tub and all the body bits go to the media blasters tomorrow
Did you use marine clean then pre with metal ready?
Or just lacquer thinner / acetone wipe?
Hey Dallas
What kind of brush did you find that works best?
What brush did you use to get inside the frame?
Any paint store (or even the big box stores) should have brushes for oil-based paints. Buy the best one they have. Actually, you probably want a couple, one wider and one narrower.
Don't paint from the can. Pour some paint into a container and work with that. It's less messy and preserves the quality of your unused paint, especially when the can might be open for long periods of time.
I saw another build thread where the guy used a (new!) toilet brush to get inside the frame. I guess the stiff bristles were good for forcing paint into all the cracks and joints. The inside of the frame doesn't have to be perfect, does it?![]()
i've never used that chassis stuff but don't use POR that shiat sucks. I've used zero rust with better results. You can brush most stuff on and it'll flow and not leave brush marks. Just remember if you have rust under there and you paint over it it's going to still rust.
Just take the engine and axles off and get the frame dipped and epoxy painted.
What is crappy about the por15 ?
Destin, If you need the correct oil filter I should have an extra one. PM if needed. Thank's, John
