Alternators will not charge when they are completely wet while submerged or right after. They dry out in a few moments and work normally.
If the water is real silty or muddy and you are completely immersing the alternator for long periods then it tends to collect the silt and mud and it can clog up the brushes if you are doing a lot of these type of crossings. If this happens, you can sometimes clean them and get it to work again with a liberal application of something like WD40 or carb cleaner. In extreme cases you might have to open the alternator up to clean it out.
Mark...
Off topic: There was some Toyota promotional sales gimmick in the late 70's/early 80's where divers drove a BJ40 (with extended snorkel and exhaust pipes) totally underwater in a couple locations in Canada. They had fun driving it totally submerged for a while, then would drive it out. I think it was one of the divers that had it on his website years ago, but it seems to have been lost into etherland.
On Topic: Louis. Have you had a wheeling season with those accordion vent tubes yet, or did you change over to them this last fall.
I brought together my rear axle, to the t-case, tied in the front axle, and extended it all up into the highest spot in the engine bay and ended with an inline filter. Things were still good after ACT2006, with no need to change. Hub seals...all of it. Lots of water crossings. Maybe I got lucky though.
gb
ForBor, you are far enough north that this trick would probably work for you.
when you drain your water contaminated gear lube, save out and leave it outside in the winter. A good hard freeze (very hard, not just a little below freezing) will separate the oil and water... thaw it, drain the water from the bottom and the oil is ready to be reused.
Synthetic should separate even easier.
I have a Royal Purple sales rep who swears that their gear oil will not emulsify. He told me that about their motor oil and I proved him wrong. I have not tried it with the gear lube yet.
Mark...
