Decoding of VIN/Frame No. HDJ810077110 for VX 80
South Africa
Can anyone assist with decoding this VIN?
The first challenge is that it is only 12 characters.
I would like to know the Production/Year of Manufacture, 1HD-T or 1HD-FT motor, the market is was manufactured, and any other information.
took me some time
LAND CRUISER VAN HDJ81V-RNPGW
1997/07 | 1HDFT VXL ATM LUB TD4 | 2AB | FQ41 | Vin/Frame: HDJ810077110
Characteristics:
VIN/FRAME
HDJ810077110
PERIOD 1997/07
MODEL CODE HDJ81V-RNPGW
CATALOG NO. 791140
FUEL INDUCTION TD4 (TURBO DIESEL 4 VALVE)
ENGINE 1 1HDFT (4200CC DIESEL TURBO)
GRADE VXL (VX LIMITED TYPE)
ATM,MTM ATM (AUTOMATIC TRANSMISSION,4-SPEED FLOOR SHIFT)
BACK DOOR LUB (LIFT UP BACK DOOR)
COLOR CODE 2AB
TRIM CODE FQ41
this is not VIN number
My understanding that a VIN and Frame Number are one and the same.
Frame # is as close to a VIN as you'll get for a vehicle that didn't have a VIN assigned. Using ToyoDIY to decode you'll get the same info as if you'd punched in a VIN.
Thanks Ian, you are quite correct in respect of Toyota DIY.
I have just checked the Frame number on the chassis (behind the right hand front wheel), and yes, 12 characters, the same as on the plate.
just saw this thread. can you guys tell the production date from this plate? trying to figure out what springs I need for my 1991 HDJ81 from dobinsons as 91 is an in between year for different part codes?
