Dash lights for 1995 80 series
Hi Everyone,
Has anyone put togther an LED kit for replacing all the dash bulbs? I mean everything from the dash to the instrument cluster lights. Its time to replace all the burned out bulbs after 15 years. Instead of just doing a few, I want to do all at the same time.
If anyone has put together a replacement kit, please point me in that direction!
Thanks,
Craig
You can start here:
https://forum.ih8mud.com/80-series-tech/213060-definitive-led-thread-80s.html
But I wouldn't use that vendor. Too expensive.
You can also look at the vendor section, there's a few guys here that sell kits.
Personally, I just buy all of mine from China direct. As a matter of fact, I just got a batch in today - I'm trying out different colors in the dash to see what I like best. Going to replace all the lights after I find the right combination of being able to see in the day and not being blinded at night...
Looking for Amber Dash Bulbs
Some of the bulbs in my '97 have burned out. I'd like to try replacing all of them with amber bulbs. Has anyone tried this? What color bulb configuration works best? Where can I order colored bulbs? Thanks for your help!
Bump, can anyone let us k is if they’ve done this?
just did this last week. there is a youtube and the biggest problem is that LEDs have to be installed only one way.
Any ways the bulbs are 194 wedge type and 74 wedge type. I ordered from superbright LED. Went with red and that is a great color as the dimmer can be left all the way up without a glare. only thing I wish is that I had done the turn signal bulbs in white and not red.
was not bad except you have to unhook gauges blind.
Again go red 194 wedge with white for the turn signal
Does anyone have a part number/s for the in dash bulbs? I’m specifically looking for the check engine light bulb.
There's a ton of information in the link found in Post #2 above:
You can do a Search for dash bulbs, instrument cluster bulbs, Combination Meter bulbs, etc in this (80 Series) forum, top right SEARCH any page.
You can also go to RESOURCES, top of the page and search for a digital download of the LX450 FSM (Factory Service Manual)
Below are a couple threads you can find using the search terms above, helps to read through them, the answer is found within:
And this one:
And another:
From the above thread (thanks to @thebfg)
1997 Toyota Land CruiserOriginal BulbCluster FilterInstalled ColorRe-Install Color
2BacklightGreen CoverGreenGreen4T10194
3Turn SignalsClearGreenWhiteGreen2T10194
4Gas EmptyClearRedWhiteRed1T10194
574 x Green, 3 x White
61Red
70Amber
86Green
90Blue
11Original BulbCluster FilterInstalled ColorRe-Install Color
12Over VoltageClearRedWhiteRed1T574Toshiba V-2
13
141st - Right on BackAirbagClearRedWhiteRed1T574Toshiba V-2
152ndABSClearAmberWhiteAmber1T574Toshiba V-2
163rdA/T Oil TempClearRedWhiteRed1T574Toshiba V-2
174thCenter Diff LockClearAmberWhiteAmber1T574Toshiba V-2
185thEmptyUnused - No Bulb
196thEngine CheckClearAmberWhiteAmber1T574Toshiba V-2
207thSeat BeltClearRedWhiteRed1T574Toshiba V-2
218thCruiseClearGreenWhiteGreen1T574Toshiba V-2
229thHigh BeamsClearBlueWhiteBlue1T574Toshiba V-2
2310thBrakeClearRedWhiteRed1T574Toshiba V-2
2411thLow OilClearAmberWhiteAmber1T574Toshiba V-2
2512thA/T PClearRedWhiteRed1T574Toshiba V-2
2613thEmptyUnused - No Bulb
Drive Mode IndicatorsOriginal BulbCluster FilterInstalled ColorRe-Install Color
38TopBacklightGreen CoverGreenGreen1T4 / T4.2V-2 JSD (10mm base)
392ndParkClearGreenWhiteGreen1T4 / T4.2V-2 JSD (10mm base)
403rdReverseClearAmberWhiteAmber1T4 / T4.2V-2 JSD (10mm base)
414thNeutralClearGreenWhiteGreen1T4 / T4.2V-2 JSD (10mm base)
425thDriveClearGreenWhiteGreen1T4 / T4.2V-2 JSD (10mm base)
436th2ClearGreenWhiteGreen1T4 / T4.2V-2 JSD (10mm base)
447thLowClearGreenWhiteGreen1T4 / T4.2V-2 JSD (10mm base)
458thO/D OffClearAmberWhiteAmber1T4 / T4.2V-2 JSD (10mm base)
469thPowerClearGreenWhiteGreen1T4 / T4.2V-2 JSD (10mm base)
47Bottom2nd StartClearAmberWhiteAmber1T4 / T4.2V-2 JSD (10mm base)
48101 x Green, 9 x White
490Red
503Amber
517Green
520Blue
Toshiva V-2 bulb replacement:
Search terms: Instrument Cluster Combination Meter Dash Lamp Lamps Bulb Bulbs
Any vendor that sells Genuine Toyota parts ie: local dealership or a few online stores.
