When my truck came back from the stereo shop recently the backlighting on the cluster wasn't illuminating. I needed to go in there and replace everything with LED's anyway I figured they just left something unplugged. Got everything out, switched out all the bulbs for LED's and was ready to rock. My half a banana mechanic ass was feeling pretty good about myself until I hooked everything up to test it, still not backlight and multiple indicator lights not working.
Is there a way to test out all the dash lights? Check to see what is working and what isn't?
My shift indicator lights work, my "cruise" light works, signals work, check engine works and door ajar works.
Seat belt light doesn't work, diff lock lights don't work, again back light doesn't work, 2nd doesn't work and od off doesn't work.....I'm sure there are others I can't test.
The tail lights work so it's not the fuse and the dimmer light switch looked to be in rough shape, plus I found an unplugged connector not sure what it's for, see pic attached. It can't possibly be that many bad LED's and of course the backlight wasn't working previously so I'm thinking it's the dimmer switch but not sure if those symptoms would account for that.....what do you guys think?
