[quote author=Poser link=board=2;threadid=6140;start=msg49345#msg49345 date=1065749297]
Was in the Hills for BHCC, didn't the yellow bus break five of those uber strong axles?
[/quote]
Yes, but I have thought about it a lot afterwards and it can all be explained. :
Woody was there, but the story is slightly different. I broke a prototype Newfield, replaced it with a new Toyota unit. I left some metal pieces in the knuckle. They were between the ball and the knuckle and I did not see or feel them when I did the swap. As soon as I started moving, they come loose and jammed the now new Toyota birfield. It did not sound right, and I broke that one before I could investigate.
Then in trying to get the truck off the trail, I broke the other side prototype Newfield. I guess that is why they are called prototypes.
In camp we replaced both sides with fairly used Toyota oem birfield. Well, they did not last long. I broke one on the trail (same spot, sucker for punishment) opted to get the truck off the trail instead of replacing yet again, and then broke the 2nd while on the road and trying to turn around and back up a steep hill.
So 5 in total. Broke 1 in the Schoolbus earlier this year in Moab when backing up a rock to save the fender from being crushed.
I am now running brand new Toyota oem birfields that has been treated by Bobby Long. I have done the whole Rubicon with these and some local trails and so far so good.
Also, have another friend that runs a 80 series axle in his 4Runner with 42's. He went through about as much as I did, but he is running some newer Newfields again and they seem to be holding.
We also have some new birfields from Australia now, same manufacturer as the Toyota oem ones, but cheaper. Those would be good candidates to have treated and then see how it goes.
For the record the tire size on the ShortBus is 39.5's
I have never seen anyone break the inner shafts. Only time they get damaged is when the brifield explodes and the splines get trashed.
That said, I think a birfield elliminator using Dana 60 parts might be nice. Not as messy to fix in the field.
