Started up the rig today and got a P0116, Engine coolant temp circuit range performance.
Following the FSM shows potential T Stat, but Robbie replaced mine with an OEM from Dan when he did my head gasket a few months ago. So, I doubt thats it.
it also says potential temp sensor.
So I cleared the code and drove around a bit with no issues. I realize its a 20 minute delay to reach 95 degC on two trips (??). So I will keep an eye on it.
The secondary reservoir was just below the bottom line, doubt that would have anything to do with it, but I filled it with Red to the halfway point between the bottom and top line.
Gages all looked good and the radiator was just flushed and filled in November when my Head gasket was done.
So, I will monitor the situation and if it comes back I will check the sensor.
What I am curious about is that while going through the freeze frame data I also found the following message. " Fuel System 1 closed loop calculated load at 62.7%". I am not sure what to do with this if its good or bad. Not sure if it could have been there before the injectors and fuel filter were replaced or if it is fresh data. I erased it before thinking about looking for a time tag.
If someone knows a little more about the Fuel System Message, that would be great
Thanks,
Ken
Thanks,
Ken
