I rebooted both of my CVs and replaced the diff seals while I was there. When I replaced the driver (left) side differential oil seal, the new one (OEM Toyota) was not a very tight fit. I could get it at least 75% of the way in by hand. I decided to go with it and now I have a slight leak. There are 2 drops of oil on my garage floor in 2 weeks. When I go back and re-do this, what can I do to make the seal tight and not leak?
Second, I have a squeak/creak somewhere in the suspension and I'm not sure how to isolate it. It's possible it's the right lower ball joint. I removed the knuckles completely when I did the CVs and not sure if reassembly could have caused it. Honestly it could have been making the noise before. The Lexus is so well insulated I can't hear it at all with the windows up. Now that it's warming up outside, I've had windows down some and it's quite loud. It makes noise just turning the steering wheel while not moving, as well as any suspension movement from bumps etc. I can push down on the bumper or lay underneath and push up on the LX and it makes the noise. The ball joint boot is intact and there is no sign of grease loss. When I laid underneath, I am pretty sure the sound was close to the knuckle, not at the lower a-arm bushings. If it is something rubber, should I try a cleaner or lubricant of some type to see if it goes away? Any similar experience or advice is appreciated.
